Has anyone used the mgo board? Looks pretty good
Last Post 16 Jan 2020 12:03 PM by newbostonconst. 2 Replies.
rookieryf135User is Offline
15 Jan 2020 01:50 AM
Magnesium oxide board is a new type of fireoroof decorative material, which is composed of magnesium oxide, magnesium chloride and water ternary system, and is made of stable magnesium cementitious material, medium basic fiberglass mesh as reinforcement material and light material as filler. Magnesium oxide plate is processed by special production process, with the characteristics of fireproof, waterproof, tasteless, non-toxic, non freezing, non corrosive, high strength and light weight, convenient construction, long service life, etc. https://en.rubriboard.com/
DilettanteUser is Offline
15 Jan 2020 06:24 PM
I've seen it used in several specialty builds where chemical and materials sensitivity for the owner were an issue.
If you're using it as sub-flooring, it generally has a bit more "give" than plywood or OSB. This can result in a subfloor system that's a bit more "springy", but not necessarily dangerous.
So, if possible, spec slightly thicker on the panels or double up.
newbostonconstUser is Offline
Sounds like a sales pitch.
everyone uses it in showers even though last I checked it wasn't UL listed or an option in the code books. There is also some horror stories when using it for SIPS, they may have gotten through those issues but I wouldn't chance it on a whole house build.
What other usages are there?
People Online People Online: Visitors Visitors: 192 Members Members: 0 Total Total: 192
