Existing Basement Insulation?
Last Post 29 Jan 2020 03:34 AM by jmon22. 5 Replies.
jmon22User is Offline
24 Jan 2020 02:55 PM
Good Morning! I am in the process of updating the basement of a late 80's home that I recently purchased. I am finishing the partially unfinished space with XPS against the foundation wall and floor, and tearing out old drop ceiling and carpet in the space already completed previously. A bit stuck on what to do with the finished exterior walls in that area that is already done (~60 ft total). They used poly against the foundation with a stud wall 1" away insulated with unfaced fiberglass. Not the worst way to do it, especially since most modern building science says to keep the moisture towards the foundation, but not how I would have done it either. Do I rip this down also and start over, or let it be and save my time and sanity? Thanks!
DilettanteUser is Offline
26 Jan 2020 02:06 PM
This is not actually a construction issue.
It's a set of nested conditionals.
How much is your time worth to you?
And how much is your peace of mind worth?
28 Jan 2020 02:37 AM
Posted By Dilettante on 26 Jan 2020 02:06 PM
I guess that depends..... what are the potential issues? Is this a horrible way of constructing a basement wall, or just less than ideal given what we know about current building science?
newbostonconstUser is Offline
28 Jan 2020 11:41 AM
Are you having problems with moisture in the walls right now? If not having problems, I would leave it.
29 Jan 2020 02:21 AM
Posted By newbostonconst on 28 Jan 2020 11:41 AM
S'trewth!
If it ain't broke, don't fix it.
Thanks fellas. No current issues to speak of. Just needed a reality check
