See layout, give me an opinion on whether this will work.
Ranch home, CZ 6 with 99% design temps of 89°F and -9°F.
Load calcs done with HeatCAD and I'm fairly well versed in load calcs and construction. I've made the assumption I can achieve <1.0 ACH50 and won't stop sealing until it's well below that level. The ICF is inherently air sealed, but I'll really work on the ceiling and openings. ICF walls are R22 below grade ICF and R22 or R30 above grade (more on this later.) R6+ windows and the percentage of glass is relatively low. Plenty overhead and under the basement slab as well.
Max heat load: ~35,000 btuh. The walls are the largest factor, but raising to an R30 saves just ~2,000 btuh peak load making it relatively unfeasible.
Max cooling: ~19,000 btuh.
The main floor bedrooms take around 2500, 2500, and 6000 btuh peak if I'm not mistaken
The heating and cooling loads are around 6,000 btuh in the lower level and the remaining is upstairs. This is/was expected and I'd like to focus on the main-floor.
The home is fairly well open concept with the great room, dining, kitchen, foyer, and even laundry are essentially wide open. The three bedrooms and two bathrooms are obviously separated by doors for privacy and minimizing the open-concept in those areas.
I'd really like heating and cooling to be done by split systems. Conceptually, I'd like a centrally located ceiling split system head(s) on the main floor and one in the basement, located in the great rooms on both floors.
I believe I'll have a hard time with the minimal airflow of the ERV, but is it feasible to use an ERV to draw air out of multiple areas of the building only to be replaced by air in the 'common areas' which has been conditioned? I intend to draw it out of the bedrooms, restrooms, etc. and put the fresh air into the great rooms. Additionally, I would expect to need a whole-home dehumidifier could potentially pull air out of the same areas (minus the restrooms for the sake of smells) and discharge dehumified air in the great room.
(note, I can't stand much noise which is why I'm headed for ICF and trying to eliminate a traditional ducted system. Additionally, I can likely mount the cassettes/splits and condensers by myself vs attempting to run copious amounts of ductwork, etc. |
