1) You can cut and piece insulation in place. You'll need to adjust trim pieces a little bit so the additional dimension doesn't make the roof look odd. 2) You could probably encapsulate the existing roof deck with peel-&-stick. Remove the shingles, of course and clean up the nails of course. Or you could replace the roof deck with something like ZIP system roof decking, WeatherLogic, or ForceField. You could then put your foam board or rock wool board over the top in 2 courses, taping the top layer. 3) Instead of relying solely on the roof decking itself, look at laying down a drainage membrane or a peel & stick setup. Properly taped and liquid-flashed ZIP/WL/FF under a couple inches of foam/Rockwool could PROBABLY do it. I'm a paranoid SOB about stuff like this though. |
