You want to talk to an engineer to make sure such a roof can maintain a snow load properly. DOUBLY important if you're going to use exterior insulation on the roof. As you will massively decrease snowmelt from interior thermal leak. Honestly, I'd go with ZIP sheating (well taped and liquid-flashed over ALL nail penetrations). I'd go with a peel & stick underlayment atop that, rather than roofing felt. And, because of the low pitch, I'd probably make the first two courses water & ice dam membrane. Also, recommend making your building a simple box. This makes it easy to tie the wall and roofing weatherproofing systems into one another, sealing the building efficiently. Then build any overhangs as architectural detail. If you want to see a high-end version (see "MO MONEY MO MONEY MO MONEY"), watch these videos. https://youtu.be/yTbMVdmnNlw https://youtu.be/IDFSnjuNl5U Keep in mind, this guy builds multi-million dollar places in the Houston area. Also keep in mind this guy is getting materials either outright DONATED or at a significant discount from the vendor. So there's exactly ZERO chance you can do it as inexpensively as he can. But the building science he's imparting is good. |
