What is the best brand heatpump for dehumidifying
Last Post 26 Oct 2020 04:05 PM by Keithww. 2 Replies.
JeremyTUser is Offline
06 Oct 2020 04:43 PM
 I could use some advice between a Trane XV18 2 zone system vs a Mitsubishi H2i 2 head mini split ducted and which is better for de humidification.  I know the trane can drop down to 25-30 percent load for long slow cycles to reduce humidity. I see that the outdoor Mitsubishi heatpump is also VS, but how well does that modulate with the multiple air handlers? Specifically, assuming a 3ton Mitsubishi H2i compressor is feeding a 1ton and a 2ton air handlers, how slow can each air handler go? the floor for the outdoor unit is around 20ish % I think. Can the 2ton handler drop to 33% and the 1ton to 66% to match the bottom speed of the outdoor unit when only one zone is calling or are they full on/full off single stage? I tried asking the saleman, but he kinda brushed off the question.
Thank you very much for advice in advance.
newbostonconstUser is Offline
07 Oct 2020 01:33 PM
Good questions, wish I could answer them definitively.
You sound like you know what you are doing. Long run time helps dehumidify.
I think you are worrying to much about dehumidification and should worry more about overall system efficiency but I don't know your reasons. Is the house overly humid or are you in a humid area?
Is this an existing house or a new build. What is your target humidity and where are you located?
KeithwwUser is Offline
If you are going with a very tight house and R25+ insulation you should consider a dedicated dehumidifier to control humidity. I've paid for an environmental study for my ICF home and was told that the AC will not run enough to control humidity.
People Online People Online: Visitors Visitors: 166 Members Members: 0 Total Total: 166
