Hello,
I’m working on a home design and
wanted to ask for any constructive comments the community might have.
We are looking to build a very well-insulated envelope with a
straightforward process that most building crews could implement. Cost
is not the primary factor, insulation-value and durability is. This is
in climate zone 5.
I’ve attached my first pass at a
shingle roof (RF-1) and stucco wall (PL-1). The basic concept I am
working with is that the exterior Zip sheathing on walls/roof is our
water/air barrier that will dry to the exterior. The interior side of
sheathing and framing would be coated in a generous pass of closed-cell
spray foam, creating an impermeable air layer. This prevents the
condensation issue of interior vapor reaching the exterior sheathing.
Extra space in the cavity would be filled with readily available batt
insulation.
Walls get Zip R12-Sheathing for the thermal
break. The roof gets a layer of rigid foam on the interior side for a
thermal break. I looked at options for applying foam to the roof
exterior (nailbase, for ex.) but I thought it would be simple and hard
to mess up the continuous seal between the Zip R wall sheathing and Zip
roof sheathing if I kept it exposed. Would it be problematic to layer
additional rigid insulation on the exterior roof sheathing as it would
inhibit drying?
I’ve attached some detail drawings showing what I currently have.
Thank you!!!
