I'm renovating an 1880s Victorian house - it's solid brick masonry walls
with (in most cases original) lime plaster on the interior, and in most
places suspended timber floors over earth. It's a lovely breathable
structure with some unwise modifications that have been added over time
and have caused some problems, particularly for the mitigation of
water vapour. I'm adding an air source heat
pump with oversized radiators, to be powered eventually by
solar
PV to keep the house warm, and adding some individual mechanical
ventilation with heat recovery devices to improve air circulation. There
are air bricks in place which seem to be providing excellent
ventilation to the subfloor where floors are suspended timber (no signs
of rot after 100+ years).
My current project is to address some serious damp/mold problems in
the back of the kitchen, which rotted out the bottom/back of the
previous cabinets (all now removed / recycled). The brick wall is
partially buried
underground, but also for some reason a former occupant installed a plastic membrane and
concrete
slab, presumably as part of a renovation on the cheap. The rest of the
bottom floor is quarry tiles on bare earth. I'd like to remove the slab
and membrane and reinstate the earth floor that was previously in place
with quarry tiles on top.
Here's my key question: what sort of soil
should
I install for the subfloor? I've been working my way through Crimmel
and Thomson's Earthen Floors book to try and get a sense of things, and
gather this should be a good mix of (mostly = 50-70%) sand, clay and
soil (at 20% or less) and maybe fibres as well. I could easily excavate
the soil necessary for this from outside the house and mix with sand,
but wonder if there would be a need to address the biology in the soil?
Also, for folks who have done this kind of flooring, what sorts of top
layer have worked? I could do a thin lime screed on the new section, but
the rest of the house is bare compacted earth, so am not sure if this
is necessary.
There's also some long term potential here for removing soil which
is against the house and replacing it with gravel and a french drain,
but that's a way off for now.
