2" foam over 1 1/2" crushed rock base
Last Post 22 Oct 2021 03:21 PM by mtrentw. 4 Replies.
ICF5789User is Offline
12 Sep 2021 12:13 AM
Hello, I am building an ICF home slab on grade with radiant heat. We are at the stage to lay the 2" foam, tubing and pour the interior concrete floor. My layers from bottom to top are 12" compacted sand, 4" of 1 - 1 1/2" gravel, 6 mil poly, 2" foam, radiant heat tubing, 4" concrete. It's been brought to my attention that the size of crushed gravel may impact the ability for the 2" foam to lay flat and/or the foam will break during the pour. Is this really the case assuming it's a relatively flat surface? I realize I probably should have used 3/4" crush rock, but replacing the 4" rock base at this point is going to be a major process. Trying to determine my options at this point, and whether this is really going to be an issue. Thanks! Steve
sailawayrbUser is Offline
12 Sep 2021 12:57 AM
As long as everything is level/flat and was properly compacted, you should be in good shape. We use self compacting pea gravel over engineered 3/4 minus compacted rock pad. Footings are poured on top of the pad and the pea gravel fills the void to the 4" EPS insulation layer.
newbostonconstUser is Offline
13 Sep 2021 11:34 AM
They should use boards to role on if they are using wheel barrows....
I agree you should be fine and have never had a problem myself.
kenmceUser is Offline
21 Sep 2021 01:17 AM
If you're still concerned after the above, perhaps a final layer of sand just to provide a smooth surface for the foam?
mtrentwUser is Offline
seems a vermiculite topping on the gravel could also be a beneficial add before foam.
People Online People Online: Visitors Visitors: 207 Members Members: 0 Total Total: 207
