Shop insulation
Last Post 16 May 2024 09:38 AM by newbostonconst. 1 Replies.
littlebossUser is Offline
13 May 2024 04:45 PM
Got a shop in southern Colorado that I need to insulate. It's 2x6 stud walls 12' tall with the center being about 20' tall. Pix of barn is attached. Walls are wrapped in OSB and then steel lap siding. The best I can tell there is no building wrap. Spray foam is too expensive so I am thinking fiberglass in the walls and after I put a loft and ceiling in it, have cellulose blown in the attic. Mice are bad there so I think the cellulose is treated. I have read that fiberglass has air currents flowing through it which reduces R value. Thoughts on either using a plastic vapor barrier on top of the fiberglass or using 2" of pink foam in the wall cavities first (caulk around them to make air tight) then add the fiberglass and OSB or tin to cover the walls? Also what about attic venting? Thanks
Attachment: barn.JPG
newbostonconstUser is Offline
If I remember right Cellulose is 4 times the weight of fiberglass....you can put in twice the fiberglass and have half the weight for better insulation.....guessing for that building using cellulose you will have 10,000 lbs in the attic.
People Online People Online: Visitors Visitors: 224 Members Members: 0 Total Total: 224
