Bay Window Wall and Ceiling Insulation in an Old Victorian House.
Last Post 07 Jul 2024 03:48 PM by OceanOdyssey. 2 Replies.
valfonsekUser is Offline
22 Jun 2024 09:28 PM
Hello everyone, We're currently insulating the external-facing internal walls of our old Victorian house and are trying to address cold bridging issues, particularly with the bay window wall. We'll use 60mm Steico wood fibre boards, Breasthaplasta Thermal plaster at 2.5 cm, and Contiga Solido tape around the windows and joists for insulation. Before installing the boards, we'll patch the wall holes with NHL2 lime plaster. I have two concerns and would greatly appreciate your insights. 1. Thermal Bridging at the Bay Window Ceiling While insulating the wall, we're worried about potential thermal bridging through the roof above the bay window (ceiling), which might not be insulated (we're not sure what's there). What are your thoughts on this? Should we: • Remove the ceiling and insulate it from the inside, or • Hire a roofer to insulate it from the outside. 2. Air Vents Above Suspended Floorboards When we exposed the brick wall, we discovered that the air vents were coming above the suspended floorboards. To mitigate this, I took the following steps and would appreciate your feedback on my approach: • Fitted a PVC air duct pipe was fitted to direct the air below the floorboard level. • Filled the excess space around the pipe with polystyrene insulation blocks to ensure the new fibreboard isn't directly exposed to the elements, unlike the old plasterboard. This also provides a solid surface to plaster on before installing the fibreboards. I would greatly appreciate any advice or suggestions you can offer, and I look forward to hearing your thoughts and recommendations. Regards, Val
smartwallUser is Offline
25 Jun 2024 01:52 PM
Confessions of a former insulation contractor. Pop a shingle off the roof cut a small hole in the sheathing and blow in insulation. Cover hole replace shingle , simple.
OceanOdysseyUser is Offline
Hi Val,
For the bay window ceiling, I'd suggest removing the ceiling and insulating from the inside to ensure thorough coverage. Your approach with the PVC air duct pipe and polystyrene insulation blocks seems solid and should work well.
Good luck with your project!
Cheers,
People Online People Online: Visitors Visitors: 175 Members Members: 0 Total Total: 175
