Looking for non-invasive indicators of drops in efficiency on my heat pump system.
Intuitively, it feels like I could look at the average runtime at each degree over time. I know other factors could affect this number but average trends over time should probably correct for that.
However, a quick GPT convo shows that looking at my power draw (kw) may also be a good proxy? I used my power draw (compressor + air handler) and rated heating capacity (Btu converted to kw) to calculate a live unit and system COP (4.7 and 4.1 respectively).
If the power draw goes up, then the COP goes down.
Is this something I could use to ID dirty coils, loop issues, etc. early? Maybe even better time my maintenance calls based on performance? |
