Solar Panels and. . .
Last Post 20 Oct 2007 02:42 PM by mmelvis. 3 Replies.
junipergrpUser is Offline
19 Mar 2007 04:21 PM
Hi I am very much a beginner when it comes to Green Building. My questions relate to the use of solar panels with other "green" components: Can solar panels be used with geothermal HVAC? Radiant floor heating? Tankless water heaters? I am in the beginning stages of building an eco-friendly home in Northwest Indiana. Any information provided would be very much appreciated.
19 Mar 2007 07:56 PM
Posted By junipergrp on 03/19/2007 4:21 PM
Ok, let's start at the beginning. There are basically two types of panels:
Solar Collectors and Solar PV Panels
Solar Collectors - Heat water or another type of fuild(usually glycol)
This heated water/fluid can be used for your domestic hot water and/or heating your home. Works well with radiant floor. If you are planning on heating your home, you'll need a large storage tank to store your hot water. Some people have been able to provide 100% or their H/W and heating.
Solar Photovoltaic(PV) Panels - Generate electricity
These panels are expensive, but there are possible rebates depending on your area. Also, you may have a utility that will let you use Net Metering. Excess electricity can be sold back to your utility(of course, you need to be grid connected).
I think one key to pulling this off, is to Super Insulate your new home. This reduces the demands that you'll have for heating and cooling your home. SIPS and ICF's(I recommend extra inside insulation) work well. Here are a couple of links:
Solar Harvest
Building Science - Net Zero Home
Enjoy!
mohaidly2User is Offline
20 Oct 2007 12:57 AM
hi iam an engineering student and iam doing a research on the photovoltic pv and i took my house like an example to determine what would the size of the panels taht i want to put it to cover a 1300 sqft home and how iam going to caculate the effeciency of eletricity and what is going to happen at the night time where there is no sun light
mmelvisUser is Offline
Solar PV Panels
A Performance Calculator for Grid-Connected PV Systems
All the information you need to get started
http://rredc.nrel.gov/solar/codes_algs/PVWATTS/
Consumer's Guide with good information on getting started
http://www.nrel.gov/docs/fy04osti/35297.pdf
The above links should get the ball rolling for you.
Have a great day
People Online People Online: Visitors Visitors: 292 Members Members: 0 Total Total: 292
