passive solar foundation
Last Post 16 Jan 2009 11:40 AM by slenzen. 25 Replies.
intransitUser is Offline
30 Nov 2007 08:15 PM
Posted By billmh on 11/30/2007 6:38 PM
I think you need to think about the entire design. One should not end up with an oven when building passively. There are many books out there that will help in deciding how much glazing you can get along with. Myself, we are building in NM with adobe. Using the walls and concrete flooring for the heatsinks, solar supported radiant floor heating as backup. Still in the planning stages, but this is the direction.
Hi bill.
Thanks for the input. do you have any 'good' books to recommend? There are so many, its hard to choose.
On this design, in theory anyway, it will be isolated heat wise from the rest of the structure.
Only when heat is desired will it have any influence on the inside temperature.
My goal is to create  a heat sink  large enough to basically heat the home by solar alone. (Not withstanding long periods of overcast weather of course).  We have been lucky weather-wise here in New England over the last few years, but generally its pretty cold around here. Windy too!
It is the back wall that i need to insulate, while retaining its thermal mass.
Upon building a scale model, ( 1" = 1' ) i have tried a few changes, one of which would involve moving the collector out about 4'.
That too opens up other challenges. :-)
Intransit
research is having confidence in nonsense. - burt rutan
billmhUser is Offline
30 Nov 2007 09:01 PM
I read your openning statement on the design and I must be a little daft because I cannot quite picture it. Anyway, James Kachadorian's book "Passive Solar House" for one. I mentioned it as well is one of the recent links on calcuating solar mass. It discusses heat loss etc through earth covered walls etc. There are others out there, but this one gives you worksheets to come up with numbers that you can understand.
I think it was mentioned earlier that if you insulate the wall you will loose it's thermal storage capability. There is a trade-off here. There is always a Trombe wall if you have the room. Still, you have to be careful about overheating. There is many a discussion about having to open windows during the day just so you can use the room, even though it is very cold outside. Anyway, this is a good book to give you some concepts about what is going on with passive solar.
wfb1952User is Offline
11 May 2008 08:58 AM
The link mentioned above isn't shown . How do I get link.
11 May 2008 12:41 PM
Heat collecting room is interesting but I'll be building on a lake lot, southern exp direct to lake so I want maximum views. I'll probably just have overhangs/awning for summer.
NAY MYOUser is Offline
22 Dec 2008 01:21 AM
I am a President of Solar Energy Development Foundation,local NGO and I would like to receive more information about solar and wind power.
In my current home I have 2 thermometers outside, one on an east window by front door and one on west. This morning the west(in shade) read -22, and the east(with sun) read +20. Amazing. I can open my front door (brown) and feel a blast of heat in between the dark front door and the glass storm door. I leave the front door open and the sun heats my slate kitchen floor even at this cold temp. Every new building should be designed for at least passive solar. It's exciting to keep working on my new home design with these ideas.
People Online People Online: Visitors Visitors: 272 Members Members: 0 Total Total: 272
