slenzen
| 06 Mar 2008 12:12 PM |
I'm planning a passive solar home in MN. In anticipation of near future breakthroughs in more affordable solar panels is there any advance prep I should think about doing in new construction? (running conduit/raceways? etc...) or is a retrofit easy and minimally invasive? How much rooftop area would be required for the panels? Home sq ft will be around 4000.
Alton
| 06 Mar 2008 12:31 PM |
Slenzen,
I just read an article the other day that dealt with retrofitting a large photovoltaic system to an existing home. Retrofitting was very expensive. This article strongly recommended that provisions be made for future PV's on new home. I believe this article stated that the retrofitting cost $12,000.
Here is the web site: http://teslafounders.wordpress.com/2008/02/25/solar-synergy/ |
slenzen
| 06 Mar 2008 12:55 PM |
Thanks for the helpful link Alton.
deneb
| 26 Mar 2008 11:19 PM |
Slenzen,
Europe is far ahead of present passive building in the USA. http://www.passiv.de will help you on your way. the IEA Annex group 32 is meeting in Trondheim this coming month and adding heat pumps to air/air heat exchangers will be part of the discussion. Controlling humidity generated in a passive home is one of the areas you should understand. Think small and add your mansion later as cost "they are a changing"! Live in one end and make your "closet" later. Smile, and whistle while you plant your garden soon. |
Topgas
| 05 Apr 2008 06:44 PM |
The only "breakthrough" that's in the pipe line now is with Nanosolar. Nano is claiming to drop the cost of PV to $ 1 watt, that's about a quarter of what the crystaliline panels cost. The only problem with thin film (Nano's) is that they'll require much more sq./ft per watt. Hopefully something changes to make PV more practical and economical. |
Jhuanger629
| 05 Apr 2008 10:30 PM |
Once you get an idea of how many kwH you're looking to fulfill, I can give you a rough idea of which modules would work, their approximate cost as well as how much the installers will be charging per watt to do all the work.
I'm not an installer myself, but we supply installers, contractors and retail clients with renewable energy solutions. |
Jhuanger629
| 19 Apr 2008 12:58 PM |
gotta give the guy props for either promoting or referring a business lol |
James K.
| 19 Apr 2008 11:22 PM |
Posted By Jhuanger629 on 04/19/2008 12:58 PM gotta give the guy props for either promoting or referring a business lol Thanks for the props, I appreciate that.
Jhuanger629
| 20 Apr 2008 12:22 AM |
Where exactly in santa monica is the home James K? i live in the area as well and would love to check it out. |
PanelCrafters
| 20 Apr 2008 07:50 PM |
'James' is spending all of his time spamming as many topics/forums here as he can.
He doesn't have time to respond at the moment. |
Jhuanger629
| 20 Apr 2008 10:52 PM |
I haven't received a pm, but seriously would love to check it out as I'm in the area.
feel free to email at john at solarblvd dot com |
