Installing solar panels onto a ceramic tile roof (that has been installed onto concrete)
Last Post 04 Jan 2009 03:31 PM by CarolVentura. 3 Replies.
CarolVenturaUser is Offline
23 Mar 2008 08:21 PM
Our concrete roof only has a 2.25/12 pitch. I had ruled out ceramic tile because of the low pitch, but found out that it can be installed with foam adhesive over a waterproof membrane. My question now is – how would solar panels be installed? Would the brackets be secured over the tile (through holes drilled into the tiles - with screws that would go through the tiles to the concrete)? Or, should they be screwed to the roof before the tile is installed?
TopgasUser is Offline
24 Mar 2008 06:41 AM
I'm no expert on panel installation but I have done my own. First panels are bolted, second the panel mounts are placed on top of the roofing material.
calilliving714User is Offline
04 Jan 2009 02:16 PM
You have to get the "standoffs" bolted directly to the roof. You having concrete roof will make this easier since you don't have to locate the rafters. Now I have never worked with a concrete roof, so I'm not sure if they put a waterproof fabric under the tiles. But this fabric ( or other water proof) material along with a water tight flashing is installed. Then the ceramic tiles are installed.
Thanks so much for the reply, but I decided to go with a rubber roof becuase I found peel and stick solar laminate that can be adhered directly to the rubber without any screws. You can see the roof installation at http://iweb.tntech.edu/cventura/RubberRoof.htm
People Online People Online: Visitors Visitors: 259 Members Members: 0 Total Total: 259
