Ground Level solar HW installations
Last Post 28 Jul 2008 11:24 PM by paulm. 3 Replies.
Stephen MooreUser is Offline
11 Jul 2008 12:40 PM
We have bought a house in western Massachusetts. The house is on the northern side of a 2 acre meadow (part of our property and can't be built upon in the future) so the southern exposure is terrific. Unfortunately the house orientation is built just about 45 degrees off... the ridgeline runs NW to SE. We're definitely going to do some solar DHW panels, but to put them on the roof would involve having to tilt them considerably, both to the south and standing them up (the roof has a 6/12 pitch, so it's relatively shallow for good capture). Canting the panels that way seems precarioius to me, and an invitation for problems from heavy weather (snow, wind, etc.) The other option is to build a base (to raise the panels above snow line) and install panels at ground level. Aside from any installation issues accessing the basement DWH heater (there are some for either choice, but managable), are there any benefits or downsides to ground based installed panels?
TechGromitUser is Offline
14 Jul 2008 11:46 AM
Personally I think it's a great Idea, it will be far easier to service the panels that are on the ground and your solar panel "field" could be easily expanded to accommodate more panels than you could possiblity put on your roof. So long as the panel field isn't too far away from the house, the voltage drop shouldn't be significant, but perhaps you should run heavier guage wire to the panel field than required to support additional panels and to protect against voltage drop.
The only thing that would concern me would be security. Copper thieves are ripping piping out anything they can get there hands on. While the black market for Solar panels isn't exactly matured yet, believe me as it catches on more in the future there will be more enough people looking to cash in on expensive solar panels. You might want to consider planting small trees around it (but not high or close enough to shade them) to shield it's visiblilty from the road.
14 Jul 2008 03:08 PM
Thanks for the reply. Just a note for anyone else reading this, my question concerns solar HW (hot water) panels, not PV panels. The security concern isn't an issue for our location, but it certainly is worth mentioning for others. I guess what I'm looking for is if there are any downsides that people know of when installing solar hot water panels near ground level. Thanks again.
paulmUser is Offline
Maintenance (you know you'll need it someday), is sure going to be easier at ground level than on the roof.
Also, depending on the slope of your collectors, a snowfield in front of them can contribute significantly to their efficiency. Some people even mount their collectors vertically, and put reflectors in front of them. That way snow/dirt/leaves can never accumulate on the collector surface.
People Online People Online: Visitors Visitors: 282 Members Members: 0 Total Total: 282
