Does anyone here have thin film solar currently?
Last Post 12 Nov 2008 09:15 AM by buggly. 2 Replies.
tlhfirelionUser is Offline
17 Oct 2008 08:05 PM
I would like to have a metal roof on the home I am designing and think this is a great option in area with high winds and hail.  I wonder how those that have used it have though of it?  Pros and cons?  Thank you in advance and have a good day.
BrockUser is Offline
18 Oct 2008 09:19 PM
I shouldn't say a whole lot about it; I have just heard it doesn't hold up well in the long run. The warrantee’s tend to be in the 10 year range where mono or poly crystalline is in the 25 year range. I also believe thin film is more affected by temperature and the output drops off much quicker as it gets hot.
bugglyUser is Offline
I do have thin solar the is made to stick right to the steel roof panels, depending on what type of roof panels you have, for more info you can contact me Thanks
People Online People Online: Visitors Visitors: 317 Members Members: 0 Total Total: 317
