Glauber salt solar storage
Last Post 07 Apr 2009 10:40 AM by slenzen. 2 Replies.
11 Mar 2009 07:52 PM
Interesting, using Glauber Salt phase change to store heat.
http://www.allanstime.com/SolarHome/Eutectic_Salt/index.html
The different mixtures of Glauber's salts, for example, have about 50 to 80 cal./gram during the phase change. Water is 1 cal./gram/deg C. So if you cycle brick, for example, through about 5 degree Celsius change, you only have 1 cal./gram. In this case you have an advantage of 50 to 80 times the thermal storage with Glauber's salts as you do with brick.
ManfredUser is Offline
07 Apr 2009 10:23 AM
hey slenzen, interesting article. Did not know it had to be a specific salt, or Glauber's salts. I thought as long as a definitive salinity level is reached you increase the energy storage/transfer.
Glauber's salts are used in Germany in herbal practice of naturopathy. In particular it is used for de-toxifying the body, ie. it is a colonic treatment. Just a side thought.
Yeah, I am surprised there isn't more info on this and more work in this area.
People Online People Online: Visitors Visitors: 435 Members Members: 0 Total Total: 435
