Solar thermal: External Heat Exchangers
Last Post 04 Sep 2009 11:21 AM by braggs. 1 Replies.
jbaronUser is Offline
03 Sep 2009 10:44 PM
I need to purchase an external heat exchanger for a 5 panel/2 tank solar thermal heating system. The system is double pumped (of course) and both sides of the heat exchanger - the drainback side and the radiant heating side - are closed loops. (The DHW is heated from the radiant tanks, if the radiant tanks are warm enough.) My city water, which will be used to fill the radiant heating side - is very hard, and will scale. But, it's a closed, 260 gallon (or so) system, and it will only scale until it's done scaling, I believe. My question is this: I'd rather use a flat plate heat exchanger, if I can do so, without worrying about scaling because of the closed nature of the system. I'd rather not use a shell and tube heat exchanger. Any thoughts on this choice? Thanks in advance, Jeff
braggsUser is Offline
1. Use a strainer on the input side of the exchanger.
2. Install balls valves so that you can backflush each side of your exchanger.
3. Clean strainer and backflush as part of your maintenance program.
braggs
