How to add solar power to my existing well?
Last Post 22 Jul 2010 06:07 AM by Jas.Dou. 3 Replies.
Roger BringmannUser is Offline
14 May 2010 07:19 PM
Hi, I have a existing 670 foot well that supplies water to my house and stables/apt.  I want to know what is a cost effective way to add solar power to the existing well/pump to provide me emergency backup if the power goes out.
Thanks!
19 May 2010 04:28 PM
Posted By Roger Bringmann on 14 May 2010 07:19 PM
Thanks!
"Cost effective" and "solar" don't belong in the same sentence as "backup".  If you have reasonably reliable power and don't expect to be out of power for many days/weeks, a battery+ inverter solution is far cheaper backup.  Solar is expensive stuff to use just to maintain charge on batteries when there's a grid available.
Sufficient photovoltaic to pump much water up 670' on an ongoing basis without the grid is going to be expensive.
19 May 2010 10:42 PM
You can get some batteries and keep them charged with solar, grid power or a small generator. Then use an inverter to power the pump. The problem is that the pump motor takes a lot of power to start and this requires a large inverter (perhaps 6x larger than you might think). You could use a 3 phase pump + a variable frequency drive (VFD) to reduce the startup power draw. Probably not worth it if you have to replace an existing pump.
Or just get a big water tank and keep it filled. Then a small pump can pump the water.
Jas.DouUser is Offline
What about a gas powered generator? As Dana1 said if you do not expect long periods without electricity it will work fine.
However there are a few dowsides like the noise and the carbon monoxide.
It will certainly come cheaper than solar power.
Good luck
People Online People Online: Visitors Visitors: 171 Members Members: 0 Total Total: 171
