bsp threads?
Last Post 05 Dec 2011 10:01 PM by Flathead. 3 Replies.
toddmUser is Offline
01 Dec 2011 09:58 AM
Anyone have an internet source for british fittings? I have an indirect tank with metric, NPT and BSP threads. Arggh!!!
snoslidr74User is Offline
02 Dec 2011 12:45 AM
Check McMaster-Carr
http://www.mcmaster.com/#brass-british-standard-thread-pipe-fittings/=f6kxeg
02 Dec 2011 12:10 PM
Many thanks.
FlatheadUser is Offline
If you use bsp fittings you are going to need a method to seal them.  The europeans use hemp.  It binds the thread up and swells up with liquid.  It's a bit like a hose fitting without the washer.  Doesn't make much sense to me that's what they do on the other side.  If your hemp days are over you could simply wind the npt into the bsp.  It works.  Coat the female thread with yr favorite sealant (gasoila), get some lock tite 55 (you tube) and heavy PTFE tape for the male side.  Not all the threads will bind but enough to do the job.  Good luck!
People Online People Online: Visitors Visitors: 192 Members Members: 0 Total Total: 192
