Brock
| 27 Feb 2012 03:08 PM |
Yes, but it is usually less than the loss in the system. I have messed with ours and doing a direct connect with a full moon at the right angle our system was making about 30 watts, during a sunny day our system makes about 2000w. The solar charge controller won't "wake up" until the voltage rises enough and it never hits that in a full moon, but just throwing an amp meter between the panels and batteries I saw the 30w. On a completely overcast day the system will generate about 200w, snow is the worst shutting them completely down :) |
