It will be placed in a concrete surround in the middle of the main living space
Seems like a no-brainer, but you might be surprised at how much heat DOESN'T go into masonry surrounding a proper wood-burning fireplace, particularly if it is a built-in. Built-ins are designed to emit heat in certain ways; not necessarily to your enclosure. I can run my wood-fired built-in for three days straight before there is much of an increase in temperature in the masonry chase surrounding it, and even then, it's not much. Also, I'm not sure if the notion of a quick, hot fire works well in anything but a masonry heater designed to be used that way.
