Off grid, no batteries to power pond
Last Post 27 Aug 2014 05:12 PM by jonr. 6 Replies.
EnergyWiseBuildingUser is Offline
26 Aug 2014 08:39 PM
We have a project. A pond, 300-400 feet from possible AC power. We are considering an off grid DC setup to run the pumps only when the sun is out. At other times power is not needed. 300-600 watts and could double as a sun shade. Is this plausible? How about this? http://www.wholesalesolar.com/solarpowersystems/cabin-2-dc-off-grid-solar-kit.html
26 Aug 2014 09:47 PM
How many gallons per minute do you need to move how many feet high?
I have panels directly driving a shurflo pump. Works well although pump lifetime can be an issue. On the other hand, 400' isn't very far.
ICFHybridUser is Offline
26 Aug 2014 09:49 PM
What are the pumps for? To fill the pond from a well? To supply water to the house?
26 Aug 2014 10:14 PM
Two pumps, one for fountain, one for filter waterfall. I am thinking two of the Jebao DC-12000 3168GPH Max Head 15.8 ft DC24V Watts 85W
27 Aug 2014 10:48 AM
My guess is that it is a brushless DC centrifugal pump and would work with 100+W panels that don't exceed 24V. Or you can use a DC-DC converter to provide exactly 24V (full output) under a wide range of conditions (> 32V panels would be a good choice). The link above appears to be a poor fit for what you need.
27 Aug 2014 04:03 PM
Posted By jonr on 27 Aug 2014 10:48 AM
Can you dumb it down a bit, solar is not my thing? What would I need, and where to get it?
OK, the following should work.
A panel like this (285 watts, 44V).
Waterproof DC/DC buck Converter Regulator 36V(29-48V) Step down to 24V 15A 360W (search on ebay)
the two pumps
People Online People Online: Visitors Visitors: 174 Members Members: 0 Total Total: 174
