Solar and Wind Power
Schneider Conext Insight Home RS-485
Last Post 05 Jan 2022 07:49 PM by
sailawayrb
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
CMDRZOD
04 Jan 2022 11:38 PM
Hi. I'm building a solar home in northern Alberta. I'm planning on having a couple HMI panels in my home to display battery and charging information. While waiting for the weather to improve I've been experimenting with my PLC (Modicon 221) which only has Serial modbus connection, no TCP. I've got an Insight home module I'm trying to connect with but am unable to pull any data from the insight unit using the RS-485. I also cannot find detected modbus devices in the device page. Is RS-485 enabled for the insight home? Also is the insight home the modbus master device? I've also tried unsuccessfully to poll the System control panel which is connected to the insight home unit through the xanbus interface.
newbostonconst
05 Jan 2022 12:34 PM
I use a Schneider PLC to merge 5 Ecobee's but no HMI and tried a AB PLC for home automation back in the day before home automation is what it is now.
The only company I know of that might be able to do RS 485 is Victron. They have some communication to Zigbee and USB that might help....
Good Luck, not sure you will find anyone on this forum to help....there are many other better forums...
sailawayrb
I don't have personal knowledge of Modicon 221 PLC, but we have used the Micro850 PLCs for many years. Newer model Micro850 PLCs support both RS-232 and RS-485 communications.
http://www.greenbuildingtalk.com/Forums/tabid/53/aff/14/aft/82183/afv/topic/Default.aspx
https://www.rockwellautomation.com/en-in/products/hardware/allen-bradley/programmable-controllers/micro-controllers/micro800-family/micro850-controllers.html
But I fully agree that you will need to find a better forum and one that focuses on this subject to accomplish your objectives.
Membership:
croccohvacusa
People Online:
