Polycarbonate for windows
Last Post 09 Dec 2011 06:02 PM by narcszm. 11 Replies.
VermonterUser is Offline
02 Oct 2008 11:09 AM
I'm considering building my own insulated windows using two sheets of polycarbonate. Does anyone know if polycarb yellows with age? Or any other bad characteristics of it?
OberonUser is Offline
03 Oct 2008 07:02 AM
Polycarbonate will not yellow or become brittle if the manufacturer used an appropriate UV inhibitor in the fabrication of the material.  However if the polycarbonate doesn't have a UV inhibitor then it will yellow and become brittle in as little as a year or so depending on UV exposure.
Polycarbonate will scratch much easier than glass - even polycarbonate with a scratch resistant coating will scratch.
A few other things that you might want to consider before building your own IG units:
The primary advantage of a modern IG (dual or triple pane) window is the ability to include LowE coating and argon gas fill in the unit.  A dual pane IG made with clear glass and air infill has very similar energy performance numbers to a single pane with storm window.  It is the add ons that increase the energy performance.
A sheet of 1/8" polycarbonate is about 10% less energy efficient than a single sheet of 1/8" glass.  A sheet of 1/8" polycarbonate is about half as good a sound blocker as 1/8" glass, if that is an issue at all.  You would need 1/4" polycarbonate to block the same level of sound energy as you would with 1/8" glass.
Additionally, IG units are manufactured with a desiccant between the lites to absorb any excess moisture that may be present in the airspace from the time the unit was manufactured.  These IG's are also manufactured using sealant systems that keep moisture out of the space between the lites.  If moisture is present between the lites, then the units will have condensation issues when the air temperature in the space goes below the dew point.  Adding the desiccant dries up the air in the space significantly lowering the dew point temperature.
I am curious why you are thinking polycarbonate and not glass?
03 Oct 2008 09:42 AM
I'm considering polycarb because it's stronger. Perhaps the way to go would be to put a layer of polycarb between two layers of glass that has appropriate coatings. I could even setup a valve for filling with argon if needed. And probably still come out with much lower cost than commercial units.
Stephen TUser is Offline
04 Oct 2008 10:41 AM
Not sure about making the middle layer from polycarbonate.
If you're thinking of argon gas filling, that means you'll need to seal the two outer and inner panes of glass together -- this is most precisely called a sealed insulating glass unit. It's commonly know as an 'IG'. If you aren't going to build an IG, there is absolutely no point in trying to fill w/ argon.
In addition to the considerations identified by Oberon i would like add a few more. You can make IG with glass because the moisture in air won't diffuse through the glass. If it could, the moisture would eventually overload the dessicant, creating condensation between the glass - long before the sealant fails. I'm told that polycarbonate is not very resistant to moisture diffusion. So if you'd like to make the middle pane polycarbonate, then it should float in the middle of an otherwise double glazed IG -- just like the decorative beveled glass in a front door.
Another consideration is that polycarbonate expands and contracts significantly more than glass - you need to leave room for it to expand; side to side and upwards (the bottom should rest on rubber setting blocks)
If you're concerned about breakage from the exterior, consider a double glazed glass IG, with an exterior ploycarbonate storm window. This quite common in northern Canadian communities that have no roads to the outside world and where kids throw snowballs and stones.
As an aside, i understand your sentiment about glass. At first glance it seems like a terrible material for windows; relatively heavy, breakable and expensive. But compared to polymer alternatives it is relatively dimensionally stable (doesn't exapnd and contract with changes in temperature), UV stable, scratch resistant, available with a variety of amazing tints & coatings and when all is said and done not that expensive.
If you're on a 'Homesteaders' budget and willing to be flexible on sizes, you can get good deals on 'overstock' from window companies. Overstock is a window company's face saving word for mistakes. Even if you don't count your time, buying overstock is usually less expensive than making your own. Whether it's just the IG or a complete window, most window companies can give you the deal of a lifetime on Overstock. The catch (and there's always at least one catch) is don't expect to find the exact size you need. Also, don't expect to find more than one of any given size.
Stephen Thwaites
Thermotech Fiberglass Fenestration
Stephen Thwaites P.Eng.<br>Thermotech Fiberglass Fenestraion<br>Ottawa, Ontario
26 Aug 2009 03:56 PM
Any new opinions on this topic? Thanks
dkazanisUser is Offline
30 Dec 2009 11:20 AM
Oberon,
I'm curious from where you get your estimate on the relative efficiency of polycarb vs glass. From what I've gathered, poly is 75% less thermally conductive than glass (.22 W/mK vs 1.1 W/mK). Vermonter, any success yet?
ducraftUser is Offline
25 Aug 2011 01:10 PM
So guys, what are you saying in essence? That polycarbonate material has more advantage over glass for windows or not? I am a window maker in West Africa, Nigeria precisely and i have been flirting with the idea switching to polycarbonate for my windows primarily because if the light weight and strength considering how easily glass breaks on impact. in our part of the world single glazed is still the most common and glass breakage is a frequent occurenece. I have been thinking a switch to polycarbonate will be smart for us here.
Lee DodgeUser is Offline
25 Aug 2011 01:41 PM
When I have done calculations on the thermal conductivity of window systems, I find that the temperature drops across 3 mm (1/8") glass panes are small (<1.0 C for total temp difference of 26 C across triple pane window), and that all the "insulation" is in the air films on the inside, outside, and between the panes of glass. Therefore, I would conclude that the thermal conductivity of the glass or other clear material does not make much difference to the thermal conductivity of the overall window system. Thicker glass, 6 mm (1/4") instead of 3 mm (1/8") would double the temperature drop across the glass, but it still would only be about 1.2 C across each of the three panes out of a total of 26 C.
Lee Dodge,
zehbossUser is Offline
18 Nov 2011 07:22 PM
Polycarbonate sheeting is superior to glass thermally and mechanically. Though there are issues of care and washing that need to be addressed. Building on site IG units does require setting up a portable clean room with controlled humidity and Merv 13 filtering. The reason polycarbonate is not used is cost. Window glass is $10 per 5 X 9 foot sheet bought in bulk at the glass Mfg. Polycarbonate 8 X 4 sheets are at least 5 times more expensive bought in bulk. If you are planning on doing this you should consider using heat block film as an intermediate film. Sound transmission through a single sheet is highly related to mass. Having each air gap a different size and filling with the heaviest stable gas will filter the sound. Polycarbonate sheets can be purchased with preferential coatings; the heat block films are also available in different coatings. The sealing tape and other supplies can be purchased as well. The other significant advantages are lower weight, and larger IGs can be built.
Brian
ICF Solutions
Engineering, Designing, and Building Passive, Net Zero, Self-Heated, Self-Cooled, Self-Electrified, Low Cost Homes
Basic shell starting at R-50 Walls, R-80 Roof structures. for $30/square foot
(360) 529-9339
narcszmUser is Offline
08 Dec 2011 07:39 PM
What most of you probably want is laminated glass. two layers of glass on either side of PVB or, if you want the strongest solution, DuPont SentryGlas. Polycarbonate is cheap, but it has a half life similar to fruit. laminated glass has superior acoustic qualities, but its thermal qualities are only 5% better than single pane glass. Look for hurricane windows for residential options.
08 Dec 2011 11:04 PM
Care to give some more info on the longevity of Polycarb? I've never before heard a reference to it having poor longevity.
I should have been more specific. The polycarbonate sheet itself will last for a very long time. However, since polycarbonate is so soft, especially when it hasn't been coated, it will not maintain optical clarity unless it is very protected and doesnt come in contact with anything that may scratch, in cases of impact, dent and scratch (mar) the surface. Look at the common uses: Windscreens and windows in race cars, eyeglass lenses, motorcycle visors... they are all short-life uses because the optical clarity is maintained only for a few days (racing), months (motorcycle use), and years (eyeglasses). Polycarbonate will simply never last for decades like glass will.
People Online People Online: Visitors Visitors: 254 Members Members: 0 Total Total: 254
