Interior fiberglass doors?
Last Post 04 Feb 2009 07:31 AM by Kyanisunrise. 6 Replies.
aardvarcusUser is Offline
19 Jan 2009 05:40 PM
Has anyone ever used prehung fiberglass exterior doors on the inside? I always like to buy exterior rated knobs for my inside doors, because they last so much longer, so I was wondering if there was some reason not to use outside doors like this? I know I would probably have to remove the threshold that comes with them. If it matters, I will be installing a solid wood floor and using painted trim.
19 Jan 2009 09:28 PM
I have used insulated METAL prehung doors inside garages.  I ordered the doors without the threshold.  Maybe you can find fiberglass doors without the thresholds.
30 Jan 2009 12:51 PM
Thanks for the info. I hope I can order them without the thresholds.
KyanisunriseUser is Offline
31 Jan 2009 12:12 PM
I don't understand what you want to gain from Fiberglass doors on the interior. You can get a solid core interior door that will produce the same results with less cost. But you can get any door hung on interior jambs without the threshold. Just have to deal with a good door shop. Not a building supply warehouse like HD or Lowes.
03 Feb 2009 01:07 PM
I was hoping to gain noise reduction and not have to repaint/maintain the door as often to keep it looking nice.
03 Feb 2009 11:48 PM
Posted By aardvarcus on 02/03/2009 1:07 PM
Noise reduction may be a valid reason to use an exterior door. Repainting? Wouldn't the same things that cause wear and tear of the paint on a regular interior door be the same for an exterior door used inside? Well, maybe they would resist teen boys' beatings better!
I can see the theory that you all are posting about using exterior doors for interior. But all can be achieved with the proper interior door. 1-3/4 interior solid core interior door is less than an exterior and will do everything that has been stated. Sound proof, better quality,  ability to use exterior lock and more resistant to damage. You can usually find this type of door for under $100, where a exterior will be over $100.
People Online People Online: Visitors Visitors: 266 Members Members: 0 Total Total: 266
