Are there any green alternatives to gypsum board/drywall?
Last Post 13 May 2016 12:00 AM by YunionBoard. 17 Replies.
citizen-greenUser is Offline
09 Mar 2009 03:01 PM
Hello,
I was reading that even though gypsum itself isn't harmful, the manufacturing of gypsum board is very harmful to the environment due to energy output required in the drying process required. Does anyone know of any alternatives that would be considered more 'green' or eco-friendly? I found one online at but they are not ready to receive orders...thank you!
greentreeUser is Offline
09 Mar 2009 07:59 PM
wood paneling from site cut trees.
10 Mar 2009 11:58 AM
Have you looked at fly ash sheet rock (drywall)?  This new board uses a waste product so it must save some energy in manufacturing.
11 Mar 2009 11:00 AM
On a similar vein, any idea what kind of problems with code i will have using 5/4 poplar for the interior, instead of drywall on osb sips? Before i knew about the fire thing i had 2000 bf of poplar "Treecycled" into 8" wide planks at a local sawyer. Plan on using for bedroom floor but if i can find a way to use it with the sips as interior i can split it and double the sq foot i have. i hope to use no drywall, but i am now learning this could be problematic. thanks michael
11 Mar 2009 09:21 PM
Magnesium oxide board?
kaitlinUser is Offline
11 Mar 2009 11:31 PM
I actually lifted some up today. It is about as heavy as drywalll, but each sheet is smaller........at leaast the ones I picked up. it may be a better alternative to drywall/ some should check into it.
Builders South London
pringstromUser is Offline
20 Mar 2009 04:46 PM
EcoBoard from Serious Materials, currently only available on the West Coast.
Magnum Board (MgO) by Magnum Building Products comes in 4x8, 4x9, 4x10 and even tapered edges if you need them. http://www.magnumbp.com/
MgO board is lighter than drywall and you can use a thinner board and have more structural strength.
23 Mar 2009 10:03 PM
What do you "tape" seams with on MgO board?
want to buildUser is Offline
01 Apr 2009 12:24 AM
From what I've been reading on one mfgrs site, there is no need to tape MgO board. http://magnesiacore.com/
the_glassmanUser is Offline
02 Apr 2009 06:23 PM
EcoRock as already mentioned is the first thing that came to my mind.
More info.
dwakUser is Offline
25 May 2009 11:45 AM
I am about to start building a three storey ICF walled apartment building in a very hot and humid country. I have become more than a little concerned with drywall mold on interior walls and am looking for a modern cost effective equivalent. Any suggestions?
dwak
25 May 2009 12:50 PM
How about hardibacker?
dwakUser is Offline
25 May 2009 05:36 PM
I'll try looking it up but I'm not familiar with it. Got any info and website?
dwak
energy_efficientUser is Offline
28 May 2009 09:08 PM
Try solarcrete - I think one of the best and most energy efficient system. Have no relation, I just know 2 people who had built w/this system.
cd
energyefficienthouse(.)com
SoCalScottUser is Offline
30 May 2009 02:30 AM
Posted By dwak on 05/25/2009 11:45 AM
dwak
Might take a look at gigacrete.com (Plaster Max - ICF)
Haven't used the product, but remember coming across it at a trade show.
arkie6User is Offline
31 May 2009 11:00 AM
dwak
It is not the gypsum in the wall board that can promote mold growth, but rather the paper facings.  Have you considered fiberglass mat faced gypsum wall board?  This is readily available in the US (Lowes carries it).  See the following link for details on one particular brand of this type of wall board.  The cost is fractionally higher than standard paper faced wall board.  This is likely what I will be using in my finished basement.
G-P DensArmor Plus
GAWUser is Offline
11 Jun 2009 08:53 PM
dwak
Depending on what country you will be building in, you could try using clay tile or block for interior partitions. I know that most of Europe uses clay blocks, as well as south americas.
I am building a home in Canada right now that has no drywall whatsoever, only concrete and clay!
YunionBoardUser is Offline
There are couple options
Magnesium Oxide Board (MGO BOARD) is fireproof, termite proof, Mould resistance, light weight, heating and sound isolation, competitive price and easy installation
Fiber cement panels is fireproof, waterproof, termite proof, Mould resistance, heating and sound isolation.
thin Mgo board could offer better strength by upgrading mesh.
Live Green With Yunion<br />
www.yunionboard.com<br />
manufacturer of <A href="http://www.yunionboard.com/product/mgo-board">mgo panels</A>, <A href="http://www.yunionboard.com/product/chloride-free-mgo-board">chloride free mgo board</A>, <A href="http://www.yunionboard.com/product/fiber-cement-panels">fiber cement panels</A>, and <A href="http://www.yunionboard.com/product/calcium-silicate-board">calcium silicate board</A>
