I would like to share a little bit about these windows with you, all. While these are just a prototype and are not yet commercially avalailable they will be in the near future. The windows or rather the window system contains glass blocks filled with water, along with a specific exterior glazing that covers the entire block assembly. The exterior glazing is a fixed unit with a u-value of .29 and a SHGC of .76, pretty good balance for a solar window. The blocks are 16" x16" and 4" thick and weigh in at 50# a piece. For this house we have 85 of these blocks along the due south facing wall. The total area of coverage is about 150 sq/ft and the total water weight is around 3,000#. They have been installed in the house since last october and have been performing better than expected. The heating system for the house did not get up and running until Feb 15th, 2009 and the windows were the sole source of heat thru the winter before that. The water in the windows acts as thermal mass storage for the thermal energy and then releases it into the house as night approaches. While I didn't start data logging the windows and house until late Feb, we did take notes of high and low temperatures thru the winter. The coldest temperature reached inside the house was 41.9F and the windows were still at 48F. This was only after 3 consecutive days with no sun, low's around -5F and high's in the upper teens. January 15th-17th 2009
( historical data ) The average high temperature reached in the windows was 85-90F on a good sunny day, even without the heat in the house running yet, and the windows not only warmed the house over the course of the day, but the house actually got warmer until about 10pm and then moderated over the night. Most days the interior temperature would rise a degree or two between 5pm and 10pm and then slowly moderate and then decline until 9am. Around 9AM, in the middle of winter, the sun starts to hit the windows and the windows quickly start to rise.
I don't know if they will ever freeze, but this winter was a good test for them. As for over heating, the window will have an exterior shading system. Why exterior you might ask? Well, you need to stop the suns energy from reaching the water in the blocks. The inventor of this window, Wendell Colson, is the VP of research and development for Hunter Douglas, the window shade manufacturer. He has developed an exterior shade that will block 70% of the solar gains while allowing for view and light to enter the space. The shades are being built right now and should be installed in a few weeks. Take a look for yourselves and let me know what you think.
Thanks, Tom Pittsley
[email protected] I have been documenting the project from the start and posting it online for all to see. Here are some links to the videos showing the performance during the winter and explaining how the windows work.
http://www.youtube.com/user/eebuilder I have also been posting blogs and pictures for the project as well.
http://tompittsley.blogspot.com/Pictures
