closing up air leaks
Last Post 11 Dec 2009 06:16 AM by cmkavala. 1 Replies.
new2geoUser is Offline
10 Dec 2009 02:14 PM
I've discovered air leaks coming in under the baseboard molding. The space was too small to shoot canned foam into - I tried. I went outside and looked under the house's skirt and found spaces where wind can rush in and up. Should I try to get a foam insulation caulk gun and use that? Will closing up the spaces cause any problems with moisture later?
Six ton WF Envison w/desuperheater, closed loops, 85 gal Marathon
Posted By new2geo on 12/10/2009 2:14 PM
Skirt?  is this a mobile, in any event if it is accessible, you can spray foam any hole penetrations, you may also find that air could be moving from the top plate penetrations as well
Base plates are the greatest source of leakage in any home
People Online People Online: Visitors Visitors: 233 Members Members: 0 Total Total: 233
