I'm starting a project incorporating many green/efficiency concepts. I’m pretty good at math and have built a computer model with solar calculator, surface (window), and overhang features. In its current form the model takes a nominal solar energy value (from outerspace = about 1.36kW/m2) and corrects for arimass, angle, and overhang. I now want to work in actual window parameter values to calculate actual heat gain/loss. This, of course, will involve the all-important “U” and “SHGC” inputs.
Where I’m stuck right now is that while I have what I think is a pretty good “incident solar energy” value for the window, I don’t exactly know how this value translates to heat (which I’ll eventually put in Btu) for a given window with given solar heat gain coefficient.
I have not spent too much time with google but so far I have not found a clear answer and more importantly I do not have the equations that handle this.
How does incident “solar energy” translate to heat? I assume once this is understood the SHGC is a direct attenuating factor. This should be fairly basic math – does anybody have some good pointers?
Very best,
-Jeff
Btw: the model I have has some nice graphical outputs including a 3-D full day/full year incident energy surface plot. I’ll post a link if there is interest.
