Math! How to calculate solar heat gain...
Last Post 12 Apr 2010 11:23 AM by vdubbin. 2 Replies.
vdubbinUser is Offline
09 Apr 2010 04:28 PM
I'm starting a project incorporating many green/efficiency concepts. I’m pretty good at math and have built a computer model with solar calculator, surface (window), and overhang features. In its current form the model takes a nominal solar energy value (from outerspace = about 1.36kW/m2) and corrects for arimass, angle, and overhang. I now want to work in actual window parameter values to calculate actual heat gain/loss. This, of course, will involve the all-important “U” and “SHGC” inputs.
Where I’m stuck right now is that while I have what I think is a pretty good “incident solar energy” value for the window, I don’t exactly know how this value translates to heat (which I’ll eventually put in Btu) for a given window with given solar heat gain coefficient.
I have not spent too much time with google but so far I have not found a clear answer and more importantly I do not have the equations that handle this.
How does incident “solar energy” translate to heat? I assume once this is understood the SHGC is a direct attenuating factor. This should be fairly basic math – does anybody have some good pointers?
Very best,
-Jeff
Btw: the model I have has some nice graphical outputs including a 3-D full day/full year incident energy surface plot. I’ll post a link if there is interest.
passivesolarUser is Offline
09 Apr 2010 05:51 PM
Some of the best info on SHGC based on angle is located in the Lawrence Berkley Windows 5 software. it can be downloaded free from http://windows.lbl.gov/software/window/window.html and then you input the glass types you plan to use as well as orientation. The outputs are very complete from relative BTU to total solar IR..... Once you download it feel free to PM me and I can walk you through your First Set up.
I downloaded and played around a little bit with the LBNL Windows5 program. It is very nice and easy to use.
By reading some of the documentation for this program I think found the more direct answer to my question. http://windows.lbl.gov/software/NFRC/NFRCSim5.2-July06Version.pdf with a little more detail in this document: http://scholar.lib.vt.edu/theses/available/etd-04212001-152253/unrestricted/Chapter3.pdf
Question: Assuming manufacturer numbers are real (not sure how big a leap of faith this is) taking “U” and “SHGC” as well as a calculated total incident irradiance from the sun (this can be found a number of ways and I already created those models) what is the instantaneous solar heat gain (W/area or Btu/area). This value can then be integrated over the solar day (where incident energy, angle, and shading all vary).
From previous research:
Incident angle – need the sun’s position and surface (window) orientation
Incident Energy – need solar constant and attenuate for air mass, angle, and overhang (shadow).
From Chapter 3 of the Window5 documents:
q = Ut*Apf(tout-tin)+(SHGC*Apf*Et)
Where: q = instantaneous enery flow (W)
Ut = overall coefficient of heat transfer (W/m2-K)
tin = interior air temp (K)
tout = exteriour air temp (K)
Apf = total projected area of fenestration (m2)
SHGC = overall solar heat gain coefficient (unitless)
Et = incident total irradiance (W/m2-K)
I did not try to balance the equation but in one place the irradiance number is in W per meter squared degrees Kelvin. I’m not sure where the degree Kelvin comes from… Thoughts on this usage?
Cheers,
-Jeff
