Low-e coating versus multiple panes, someone help!
Last Post 28 Aug 2010 11:09 PM by BlackHatch. 7 Replies.
the_goodinUser is Offline
16 Jun 2010 01:08 PM
So the thing I keep hearing about energy efficient windows, is that low-e coating is the way to go over double or single pane windows.
The pros for Low-e coating seems to be that you don't have to replace the IGU's just a couple of years down the road while getting almost the same insulation. What does everyone think about this? Educate me! haha.
bobarchitect39User is Offline
23 Jul 2010 11:21 AM
Low-e coating just means that they put a microscopically thin layer of some deterring metallic substance onto a window glaze (i.e. the glass). This technique is typically used on double- or triple-glazed window units. You aren't likely to find any energy efficient single pane windows out there, it's just not possible with only one layer. It's also common to use multiple methods such as low-e AND a gas fill.
BRINDASBABYUser is Offline
23 Jul 2010 11:32 AM
the insulation of a window with clear glass and LoE 272 or LoE 366 (Cardinal brand glass) is about as different as night and day. You can tell a huge difference between the heat build up on a double-pane window that is clear glass and one that has a loE coating if the window is in the direct sun. I wouldn't have a window in my house without LoE coating on it.
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Hot Springs Village, AR 71909
Office: 1-501-984-6074
Fax: 1-501-984-6073
Email: [email protected]
JohnyHUser is Offline
30 Jul 2010 12:44 PM
BRINDASBABY "I wouldn't have a window in my house with LoE coating on it."
What are you inferring? Please explain!
John
02 Aug 2010 05:54 AM
I love the Low e coating, I use it in every house I build, it reflects to the heat side ......... keeps heat in during winter and heat gain out during summer
02 Aug 2010 07:54 AM
Unlike Argon gas, I think the low-e coating will stay around for the life of the window.  I like Argon in windows but I can not find any standards for its use and life in windows.  Window manufacturers have told me that the gas will slowly escape.
02 Aug 2010 11:34 AM
i apoligize regarding my typo.  my post should and now does say "I wouldn't have a window in my house without Low-e glass"
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Fax: 1-501-984-6073
BlackHatchUser is Offline
Posted By Alton on 02 Aug 2010 07:54 AM
Alton,
Most manufacturers are utilizing a dual sealed IGU.  The primary seal is to provide the stability for the separation of the glass and grids as well as a barrier against other atmospheric gases.
The secondary seal, usually PIB-Polyisobutylene (Butyl) rubber, provides the seal against gas loss.  Most manufactures are projecting gas loss rates of less than 2% per an um.
People Online People Online: Visitors Visitors: 128 Members Members: 0 Total Total: 128
