Roof shingles
Last Post 04 Mar 2011 01:23 PM by BRINDASBABY. 8 Replies.
geomeUser is Offline
03 Mar 2011 05:09 PM
No roofing materials section of the forum?  I'll post here...
We had some wind damage to our asphalt (onyx black) roof shingles.  This has created an opportunity for us to replace the heat soaking black shingles with something different.
We were originally thinking of white asphalt shingles, but we are afraid of roof algae making it look awful (we have some North facing roof areas.)  There are algae resistant shingles, but the warranty is not great on the algae resistance part of the shingle.
There are some Energy Star rated shingles available (like Owens Corning Duration Premium Cool shingles) in medium shades with .25 Initial Solar Reflectance.  I'm not sure if this is significantly better than a standard Duration shingle with a similar shade (although the Premium may be a thicker shingle.)
Any suggestions on shingles?  Am I failing to consider other materials or better installation options that would help with energy efficiency?  Location is SW Virginia.  Budget won't allow for much more than that of replacement Premium asphalt shingles.
Thanks!
BRINDASBABYUser is Offline
03 Mar 2011 05:15 PM
Check out Atlas Roofings Pinnacle Brand Shingle. They actually just increased the warranty to a LifeTime Warranty instead of the typical 35 year on their Architectural shingle.
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Hot Springs Village, AR 71909
Office: 1-501-984-6074
Fax: 1-501-984-6073
Email: [email protected]
03 Mar 2011 05:22 PM
Have you ever noticed that shingles are free of algae that are below galvanized flashing?  This leads me to believe that installing zinc strips of metal along the ridge line would keep the shingles below free of organic growth.  Anyone have any experience with this concept?  If this idea will work, then lighter color shingles could be used more often.
03 Mar 2011 05:24 PM
yes it's called shingle shield zinc strips and they work wonderfully.
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Fax: 1-501-984-6073
03 Mar 2011 05:52 PM
Installers have told us that many shingle companies are following suit with the lifetime warranty. The Duration shingles we are looking at are lifetime too, but prorated down to 20% after 41 years. Guess that is better than zero. :-)
The algae warranty is 10 years, but prorated after the first year. Nothing after 10 years.
I'll look up the zinc strips. Have you used them? I also read that copper works, but zinc would probably look better with the shades from white to gray that we are considering.
03 Mar 2011 07:15 PM
Brindasbaby,
Thanks for posting about shingle shield zinc strips.  I did not know a product already existed for this application.
arkie6User is Offline
04 Mar 2011 01:43 AM
Posted By Alton on 03 Mar 2011 05:22 PM
http://www.zincshield.com/home.html
04 Mar 2011 12:59 PM
Has anyone used a radiant barrier with roof shingles?
 - never mind.  It appears that an airspace would be required.
We sell TechShield Radiant Barrier and have had no issues when using with roof Shingles.
Thank you,
Matthew Burr
Window & Door Buyer
Village Home Center
4650 Hwy 7 North
Fax: 1-501-984-6073
People Online People Online: Visitors Visitors: 218 Members Members: 0 Total Total: 218
