High Solar Heat Gain Window Manufacturers
Last Post 16 Nov 2011 06:15 PM by WindowsonWashington. 2 Replies.
Lee DodgeUser is Offline
15 Nov 2011 03:46 PM
I am concerned that in the IECC 2012 codes, the maximum U-values in northern U.S. climates have been lowered to 0.32, making the use of high solar heat gain coefficient (SHGC) windows more difficult, since high SHGC windows have increased U-values due to slightly increased radiative heat transfer in the near infrared. In sunny northern and central U.S. climates that are predominately heating, and where houses are not shaded, my calculations show an advantage of going with higher SHGC's, which would also increase the U-values. I am looking for a list of window companies that still provide high SHGC, low-e windows, that I can include in a report on the subject. My current list includes the following (probably compiled from discussions in this forum): Pella (Designer Series only), Thermotech, Inline, Fibertec, Serious, Milgard, Accurate Dorwin, Gienow, and Marvin. This list does not need to be all inclusion, since there are a zillion window companies, but I would like to include some of the major players. Thanks for the help.
Lee Dodge,
ICFHybridUser is Offline
16 Nov 2011 08:59 AM
Yeah, that whole low-SHGC drive is concerning, particularly up here in the northern latitudes.
However, my understanding is that ANY window manufacturer with made-to-order window lines can and will put whatever glazing in there that you specify. I'd be interested to hear which manufacturers, if any, stock ready-mades with the high SHGC glass.
WindowsonWashingtonUser is Offline
Any manufacturer that uses Cardinal glass can get you the high SHGC range glass.
All of the major manufacturers have a version but Cardinal's is probably the most technologically advanced.
The difference is clear
People Online People Online: Visitors Visitors: 176 Members Members: 0 Total Total: 176
