With a tilt&turn window, in the tilt position it will allow for venting on top but it cannot be pushed open without closing it and turning the inside handle. Can someone lean on the window and try and force it open? Possibly but it would require breaking all the pins and brackets in the window assembly and it would be very loud and require a lot of violent force, even then I don't think it would be easy to get it to open.
Out of any window design (casement, single hung, slider), the tilt&turn when in the tilt position is the most secure when open. If a casement, single hung or slider is left in the partially open position, it can be easily opened and entry can be made.
While not specifically an Intus window, it is a Euro tilit&turn and it explains it quite well:
Tilt & Turn OperationHere is the Intus video:
Intus T&T
