you'd have to partially heat the uninsulated basement anyway to prevent this.
As the success of unheated FPSFs shows, you can make use of only ground heat to prevent a foundation from freezing. No freezing, no concerns about direction. It would be interesting to confirm that the passive houses with basements are doing this.
Paul Eldercamp suggests that the basement essentially be eliminated
It's clear that he is suggesting that that is easier (and I agree), but if you decide to have a basement, he writes: "decouple it firmly".
"And here in New England, there is no "free heat" to gain from the dirt; it's always colder than the basement should be." TESTIFY, brother Robert!
Except that "free heat" isn't what I wrote.
