Posted By Myrtleboone on 13 Dec 2012 10:00 PM
Actually, the wall system is very nice and has a good price point. Check out: www.raycore.com
They have a very nice product that works well. Please review and tell me your thoughts regarding the foil faced walls.
Thanks.
Where do I begin?
I guess I'll start with "what arkie6 said", followed by "what jonr said". The whole-wall performance isn't anywhere near what their promotional literature implies.
The foils are still a moisture trap for the structural timbers within the panels, but the extemely low vapor permeance of the high-density polyurethane is almost as vapor retardent as the foils. It's not easy for moisture to get in, but once there it never gets out. If they don't build with kiln-dried timbers it could still be a real problem even without moisture leaks from nail penetrations, etc.
But then there's the worse stuff:
It's all done with closed cell polyurethane foam, the vast majority of which is blown with HFC245fa, that has more than 1000x the greenhouse potential of CO2, and more than 50 years worth of the greenhouse gas emissions of the energy use it's offsetting. While there are some very low greenhouse potential blowing agents being developed for polyurethane they are not on the market yet, and they don't have a track record for how well the perform on long-term shrinkage issues that has plagued closed cell polyurethane goods- it's a touchy chemistry.
If you're going to build with SIP type panel system, go with EPS cores, which are blown with pentane, not HFCs. Pentane-blown EPS has less than 1% of the lifecycle greenhouse potential of a polyurethane-core version of equal performance. It will be ~50% thicker than a polyurethane SIP, but even an R50 SIP is only about 12.5-13" thick.
EPS has long term shrinkage issues too, but those aren't much affected
by blowing agents, and there is now a 20+ year history on pentane-blown
EPS, and it's no worse than when it was blown with ozone-layer damaging HCFCs- if anything the switch to pentane has been an improvement regarding aging issues.
A few manufacturers (eg Huntsman) make structural polyisocyanurate core panels which have nearly the same R-values as polyurethane at a given thickness, but like EPS most polyiso is blown with pentane these days, not HFCs.
