Posted By Gold Star Construction on 02 Jul 2016 04:04 PM
We have used it over ICF as a primus replacement. Same base coat method as Lbear mentioned but we used 11 oz recommended mesh instead of 4 oz mesh as that is standard stucco practice. We then applied stucco primer and elastomeric stucco over it so it would match installation methods and not confuse installers any more. Simple just mix their mix with water and apply to a clean eps surface. We have one over 6 years and another 2 years and no noticeable cracks and very water resistant. Pricey though. Owner was tired of standard stucco practices and cracking issues. He did not want standard skim coat or traditional hard coat stucco on lathe on his ICF home.
So you applied StuccoMax, let it cure, then applied another type of elastomeric stucco over the StuccoMax?
Did you hand trowel StuccoMax or use a hopper/spray gun?
