Interior finish for ceiling of an un-conditioned space with conditioned above
Last Post 17 Jan 2017 08:58 PM by Nashvegas. 1 Replies.
doooglasssUser is Offline
17 Jan 2017 03:47 PM
I have a small ranch (1800 sq/ft) that I've been working on. The house has a main floor that is above a conditioned/heated basement and an unconditioned garage (22'w x 24'd).
I installed in the joist bays suspended tube radiant heat 1" from the subfloor, a double foil staple-in radiant barrier 2" below the pex tube and finally R13 fiberglass rolls (paper side up).
My question is regarding the unheated garage ceiling. Originally I was going to use 5/8th sheetrock for the ceiling to stop some sound, but it's my understanding the R value is about .55 - I'm considering using 1.5" EPS board @ R5.78. Additional cost would be ~$4 per board and I would plan on painting them white. It's a garage I use heavily so it needs to reflect light well.
Has anyone done this or do you have a better/cheaper material you can recommend? I am just trying to make the home efficient, save on heating costs and be more comfortable. Location is Long Island if that is relevant.
NashvegasUser is Offline
The eps isn't a bad idea, but you still need to cover it with 5/8" sheetrock to meet fire code..
People Online People Online: Visitors Visitors: 202 Members Members: 0 Total Total: 202
