Windows/Doors and Interior/Exterior Finish
insulate 80 yr old brick ranch
Last Post 26 Jun 2024 02:09 PM by
newbostonconst
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Stetz
23 Jun 2024 11:01 PM
I recently removed old plaster that was peeling paint badly. The interior of the wall is wood sheathing 7 inch wide on the diagonal. The sheathing has tar paper between itself and the exterior brick. The top 1 foot of the wall is the exterior soffit. I was planned on using rockwool as the insulation, with a vapor barrier behind the drywall, and spray a waterproof sealer on the brick. My question is that the top of the wall where the soffit is you can see some daylight and i can feel a difference in the temp on the sheathing. I am worried about possible moisture with the temp difference in the soffit area. Is there something else i should be doing to make this be effective. Thanks
Stetz
23 Jun 2024 11:41 PM
Should also add that i live in south carolina
smartwall
26 Jun 2024 11:46 AM
I don't understand why you can't insulate behind the soffit from inside. Why are you spraying the brick?
newbostonconst
Paint pealing on plaster usually means a moisture problem....
Membership:
croccohvacusa
People Online:
