commercial rubber roof coating
Last Post 01 Dec 2011 11:52 AM by Grailey. 29 Replies.
10 Aug 2010 06:48 AM
Posted By greencleaning on 10 Aug 2010 04:53 AM
Rubber is not that advisable to repair or replace your roof, I'd rather go with slate for it's durability or metal roofing since 90% of metal can be recycled.
the original post was for a flat roof, slate or metal cannot be used for flat roofs.
greencleaningUser is Offline
16 Dec 2010 07:01 AM
Liquid rubber may use in this problem; this coating has 300% elasticity. Liquid Rubber forms a waterproof and seamless coating immediately when applied. It will even standup to a light shower even when the material is still drying. Liquid Rubber retains its specifications even in extreme temperatures. Liquid Rubber will take temperatures from -60 to 300 degrees. It is resistant to UV and Ozone, can be used with full confidence on places that are exposed to constant sunlight. Liquid roof features very high flexibility and crack-bridging ability. I hope it can help you decide what to use in repairing your roof.
Here's to you, your health and the health of your family. <a href="http://www.cleaningcleaner.com">Eco friendly cleaning</a>
16 Dec 2010 07:19 AM
Posted By greencleaning on 16 Dec 2010 07:01 AM
Your previous post said "Rubber is not that advisable to repair or replace your roof, I'd rather go with slate for it's durability or metal roofing since 90% of metal can be recycled"
So where do you really stand on rubber?
02 Jan 2011 09:36 PM
The rubber sheet is placed on the roof over a strip of wood, called a batten, about 6 inches from the edge of the gutter. The sheet is stapled or tacked at the edge. The sheet must overhang the side edges to be fastened down later. The rubber sheet can now be hung over the edge of the roof, turned under into the sheet so you can no longer see the batten.
KBSCoatings14User is Offline
11 Jan 2011 11:24 PM
I think Rubber roof coatings for mobile homes are paint-on products designed to protect the roof as well as waterproof seams. Recoating the roof needs do be done every few years. The exact number of years between recoatings depends on the quality of the coating product. This information will be stated on the containers of roof coating. Failure to recoat your mobile home roof when required can result in water damage to the interior of your mobile home.
For more Information visit KBS Coating Australia
jumpingspidermediaUser is Offline
13 Jan 2011 08:05 PM
Typical roof coating dry film thickness vary from paint. This means a roof coating actually becomes the top layer of a composite roof membrane and underlying system. A roof coating can be applied by brush,roller or spray. An airless sprayer is recommended  for best results!
<a href="http://www.londonccc.co.uk/">Carbon credits</a> | <a href="http://www.londonccc.co.uk/content/self-invested-personal-pension">Carbon investment</a> | <a href="http://www.londonccc.co.uk/content/what-are-carbon-credits">Carbon trader</a>
tejalUser is Offline
03 Feb 2011 06:35 AM
Nice post,
There are two types of roofing vents. The first type is the passive option. The passive variety use only the air movement to work. Ridge, soffits, flat, pot and turbines are all examples of passive vents. The other is an active alternative that uses solar power or electricity to power them. These are the solar and exhaust fans.
patriciaaUser is Offline
24 Aug 2011 12:11 AM
<!--[if gte mso 9]> Normal 0 false false false EN-US X-NONE X-NONE Construction technology today also covers a whole new field of green buildings. But are they cost effective enough to be recommended for mass production.
AlexaWardUser is Offline
11 Oct 2011 02:40 AM
I wouldn't use any kind of coating material on a rubber roof. the only way to properly repair any of the problems you mentioned is to remove the the old material and replace it with new material. Only hacks use cheap coatings on a rubber roof, IF YOUR GOING TO A JOB DO IT RIGHT IT. It takes minimal effort to remove old flashing on an EPDM system.
<a href="http://www.apartmentcafeteria.com">Apartment Rentals</a> with user reviews, amenities and location Map.
GraileyUser is Offline
Try using a Leak Diverter to temporarily stop leaks and buy you more time until you can make permanate repairs. For more information visit: www.graileyleakdiverters.com
Membership Membership: Latest New User Latest: HotnCold New Today New Today: 0 New Yesterday New Yesterday: 0 User Count Overall: 34723
People Online People Online: Visitors Visitors: 142 Members Members: 0 Total Total: 142
