I am renovating a 42' x 60' concrete shell building to use for my printshop.
I plan to insulate it well, including 2" foam (Foam Control brand) insulation under new concrete slab. I am looking for advice on whether to use 2# foam rated at 25psi compressive strength or to go with the heavier 2-1/2# material rated at 40psi.
Currently my heaviest press weighs 8,000 pounds with about 4' x 5' footprint. I will be bringing in paper skids weighing up to 2500#
I called a local engineer (Wheeling WV area) who scoffed that "no one insulates under slabs" and said he couldn't help me.
The price difference doesn't seem excessive, so I'm inclining to go to 40psi for the heavy load areas for peace of mind unless consensus is that 25 is ample.
