<!--[if gte mso 9]>
Normal
0
false
false
false
EN-GB
X-NONE
X-NONE
MicrosoftInternetExplorer4
Philadelphia, PA (April 5, 2011) - Eneref Institute will sponsor an LED
luminaire discussion during LIGHTFAIR 2011 examining the use of
reflectors in luminaire design to shield the LED light source. The
45-minute discussion, entitled “Let’s Bounce: LEDs + Reflectors”, is a
continuation of a report published in the January issue of LD+A magazine
(Lighting Design and Application) by the Eneref Institute examining the
use of reflectors in luminaires in commercial retrofit applications.
Optical surface manufacturer Alanod
Aluminum will present when best practices calls for bouncing LED light off of
the reflector, instead of sending the light through a lens or refractor.
The LIGHTFAIR discussion, hosted by Eneref
Institute, is complementary to businesses involved in luminaire and lighting
design, and is part of a continuation of the Eneref Institute report on the use
reflectors for energy savings in luminaire design.
LIGHTFAIR 2011, Pennsylvania Convention
Center, Philadelphia, Room 300.
Tuesday, May 17th at 10:30 AM or Wednesday, May 18th at 2:30 PM
To register for “Let’s Bounce: LEDs +
Reflectors”, email your contact information to: [email protected]. Or register online on
Events at www.eneref.org.
About Eneref Institute
Eneref Institute is an independent
organization whose mission is to investigate the efficacy of sustainable
building projects, provide relevant case studies and advance individual
leadership. The Nairobi-based research center explores the economic benefits of
sustainable advances in the residential, commercial, industrial and
institutional facility market sectors. Eneref enjoys the sponsorship of leading
organizations in the sustainable building and design industry.
