Wood Frame vs Steel ?
Last Post 07 May 2017 05:51 PM by Arnold12. 14 Replies.
Author Messages Not Resolved
TerryUser is Offline
27 Feb 2016 06:03 PM
I'm looking at building a small commercial bldg. as per submitted photo (50'x 120'), with wall heights in excess of 20'. With the availability of engineered wood products achieving enhanced structural capabilities, I am curious why such projects are seemingly few and far between? Any feedback would be welcome.
HP HomeUser is Offline
29 Feb 2016 09:41 PM
It depends but usually with the bigger spans steel is cheaper.
sybilthunsUser is Offline
22 Jun 2016 03:09 AM
Yeah I too agree with HP home, Steel is cheaper.
steelllcUser is Offline
24 Aug 2016 07:18 AM
Wood is a conventional material used for building purposes. In spite of being the oldest used material it lacks few properties that steel has. No doubt that Steel is one of the widely used building materials around the globe, and yes it is cheaper when bought in good quantities. With the scope that it can be recycled up to 98%, makes steel one of the most preferred metal.
Talking about the cost involved, Steel buildings normally range from $50-$70 per sq. ft. That's a bit costly as compared to wood.
I would suggest using steel for major supporting structures of your building along with the wood. Also with the mix of wood and steel the cost will be less. This will not only give you flexibility in building but also provide strength to the structure.
26 Aug 2016 09:04 PM
Posted By Terry on 27 Feb 2016 06:03 PM
For general dry storage steel is by far less expensive , it is more difficult to make a wood framed building in excess of 20 ft high structurally stable at a reasonable cost
26 Aug 2016 11:20 PM
Thank you all for your responses. In my region, I sure do not find steel to be a reasonable option when compared to wood.
27 Aug 2016 02:07 PM
what is your region
27 Aug 2016 03:09 PM
If you live near timber country, then lumber is the least expensive way to go. They are now making multi-story high-rise commercial buildings using LVL/GluLam beams.
There are pros/cons to each. With steel beams, attachment is the issue. One just can't screw into it with screws. Steel is a horrible thermal bridge (if that matters to you) and it has no R-Value to it. Heavy timber is easy to attach to, has good R-Values, and is actually quite fire resistant due to the dense LVL/GluLam.
Depending where you live, steel I-Beams might be cheaper but they might be more expensive. Call around and price it out. Everything is regional. What costs less in Georgia will cost more in Utah. Truck freight is not cheap.
27 Aug 2016 03:40 PM
Just north of Edmonton, Alberta where everything seems to cost more than every where else...lol. I will see if our provinces latest bust phase does anything to change the numbers I have seen so far.
27 Aug 2016 03:50 PM
Thanks Lbear, I tend to agree with most everything you have stated. I'm in Alberta Canada. I just so happen to love wood products...period. I'm also a level one certified thermographer, so I know a lot about heat transfer via the usual methods. I do have to say that Sips do combat a lot of those issues, but like everything else, come with their inherent strengths and limitations, dependent on the project.
27 Aug 2016 04:19 PM
I had the occasion in 2013 to do some consulting for the Kehewin Cree Nation that was east of Edmonton. They were constructing a new administration building with SIPs. On the trip there saw a lot of heavy steel being used for the oil industry, maybe their use is driving cost of steel up in your area. I do cost analysis from time to time for steel stud vs. wood studs and last I checked it was the same cost either way.
StephenHUser is Offline
06 Mar 2017 07:52 AM
The answer to that question depends on your priorities.
Steel-frame buildings are a good fit when you need extremely wide (well more than 100') clear-span interiors, such as in a large manufacturing facility. Wood trusses max out at about 100'.
For metal buildings less than 100’ wide, a wood post-frame is generally a better choice for the following reasons:
Design Flexibility
It is much easier, and thus less expensive, to get higher-pitched roofs, interesting roof lines, overhangs, dormers, offsets, etc. on wood-frame buildings than steel-frame. That’s why it is so common to see steel buildings with extremely low-pitch roofs and no overhangs.
Energy Efficiency
Post-frame buildings are easier to insulate and don’t suffer from the extreme thermal bridging of steel-frame buildings. Learn more about the energy-efficient attributes of post-frame, steel-frame and block.
Savings
Lumber is nearly always less expensive than manufactured steel beams, sometimes substantially so. The lower material costs in a post-frame building translate into savings for you.
claudcongerUser is Offline
17 Mar 2017 06:40 AM
I've heard some contractors won't use steel in basements because if the basement floods,
steel rusts and it compromises the integrity of the stucture?
17 Mar 2017 09:26 AM
While it may get wet, I would think that it wouldn't stay wet for very long. Or if it does, there are going to be numerous problems.
Arnold12User is Offline
steel
People Online People Online: Visitors Visitors: 212 Members Members: 0 Total Total: 212
