Green security lighting
Last Post 02 Dec 2008 10:51 AM by Dana1. 8 Replies.
niceguy1129User is Offline
08 Apr 2008 07:49 PM
I live in rural KS and have two dawn-to-dusk 175 watt mercury vapor lights on my property. I've been looking for a more energy efficient option. I like the amount of light and the durable housings of the mercury vapor lights but don't care for the high electricity cost. Any suggestions? I don't want to spend an arm and a leg to replace. Thanks for your thoughts.
Barney LoweUser is Offline
13 Apr 2008 10:14 AM
There are both flourescents cabable of 120 watts outputs
http://www.buylighting.com/Compact-Fluorescent-Flood-Lights-s/114.htm
and LEDs available
13 Apr 2008 01:43 PM
Fluorescent lights used in cold temperatures may require a special ballast.  Consider LED's instead.  Longer life - more efficient.
13 Apr 2008 08:27 PM
As proven this winter, we get quite a lot of cold weather in the winter. I'm not sure the CFL's would do well when temperatures go below 20 F. I'm intrigued by LED and am unaware that LED's have been developed to throw the same amount and pattern of light as a traditional mercury vapor light. Any more info on where to find this option would be appreciated.
BrockUser is Offline
23 Apr 2008 12:46 PM
I would look at a smaller high pressure sodium, maybe a 70W would do the trick. Right now high pressure sodium is still the most lumens per watt (light out per watt) in an off the shelf item. They are about twice as efficient as mercury vapor, so halving the wattage you should still get the same light out. Compact fluorescents typically fall between mercury vapor and sodium lights. Led’s can be more efficient, but to get that many lumens out your looking a custom fixture $$$.
Road BlockUser is Offline
12 May 2008 07:35 AM
I have seen low temp cfls for sale. I can't find the lik right now but two years ago they were $6-8 each and would start in temps as low as -20. I'll continue to look for the link.
12 May 2008 07:48 AM
Not the site I was looking for but http://www.sylvania.com/AboutUs/Pressxpress/Pressnews/DuraOneExpands.htm supposed to start at temps down to -20. Another option is LED, very expensive up front costs though. Go to cree.com and you will find some partners that specialize in public area lighting with leds.
WolfUser is Offline
21 Nov 2008 02:40 AM
A HO ballast is rated to start at 15 to 20 below but it may never heat up enough to give you the light you desire. Judging by what you have at the present time. And if it that ballast doesn't reach the temp it likes the amperage will run higher than normal. I've installed metal hallide on the outside of warehouses that seem to do pretty good in the cold. Not sure of there efficiency though.
http://www.wolfenergysavings.com/
Mercury vapor typically runs with ~45 lumens/watt (+/-) efficiency.
High pressure sodium runs ~110lm/w, so you can cut your power in half and get you get the same luminance, with similar color rendering (albeit a different color)
Low pressure sodium is higher efficiency still but has the worlds crummiest color rendering- it's more light, but due to low CRI the experienced visibility to the eye is somewhat worse. Black & white security cameras can use it though.
Metal halides run about 80lm/w, and have considerably better color rendering- you can probably run about a quarter to half the power of your mercury lamps and get better overall visibility, if naked-eye (as opposed to camera) view is what you're after.
People Online People Online: Visitors Visitors: 126 Members Members: 0 Total Total: 126
