Venturi Showerhead
Last Post 26 Jul 2010 09:24 AM by jonr. 7 Replies.
michaelcherrUser is Offline
09 Apr 2008 03:53 PM
Does anybody have experience with Venturi style showrheads?
Are they as good as advertising claims them to be.
The basic claim is that the showerhead areates the water, (increaces it's volume by mixing in air)
You can then reduce the GPM flow without sacraficing water pressure.
There are also claims that the areated water softens skin and hair.
They can get quite expensive for a good one.
Is this style showerhead worth it?
JarrahUser is Offline
28 Apr 2008 08:51 PM
I have used a venturi style showerhead for a couple of years.  I have had no problems at all.  I had been concerned that the tiny outlet holes might clog but this does not seem to have happened even though I have had lots of plumbing work done at my house which must have sent a fair amount of detritus through the pipe to the shower head.
I have regular low flow shower head in a second shower which by comparison seems to just trickle out the shower water.
The air flow creates makes the shower head a little more noisy than a regular showerhead but not to an extent that can be noticed outside the bathroom.
The brand I bought is manufactured by an Australian company e-co (ecoshower.com.au)
bonnie0715User is Offline
17 Nov 2008 12:57 AM
Venturi Shower head with an accelerator fin speeds up the flow of water, passing it through a Venturi and mixes it with oxygen, increasing the oxygen content up to 10 times. This process increases the outgoing water velocity. The result is an exhilarating, pulsating, spa-like shower.
WobblyUser is Offline
02 Dec 2008 12:11 AM
Posted By bonnie0715 on 11/17/2008 12:57 AM
[/quote]
This appears to be marketing hype. Take a look at this animation of flow in pipes:
 Notice that the velocity downstream of the venturi is reduced.
02 Dec 2008 09:07 AM
That animation is backwards relative to how this priciple is used in the showerhead.
The animation shows pressure and speed positivily correlated (in this case pressure goes down, so speed goes down)
If that animation flowed the other direction, (pressure increases), then the speed would increase.
In the animation the changing diameter of the pipe is used to change fluid pressure.
In a venturi showerhead air taking up volume causes an increase in pressure.
02 Dec 2008 09:48 AM
The animation parameter values can be varied by dragging on the yellow handles. Bernoulli's Principle states that as the speed of a moving fluid increases, the pressure within the fluid decreases (and vice-versa).
Ana72User is Offline
26 Jul 2010 09:14 AM
I haven’t had any experience yet using Venturi Showerhead; however, what you should know is that what type of showerheads you are going to avail as it should suits your taste and preference.
There are four types of showerheads available in the market such as fixed showerheads, shower body jets, shower handsets, and dual showerheads.
Fixed showerheads would allow you feel like bathing in the rain and its water flow is steady, nevertheless, its disadvantage is that it has a limited mobility due to the fact that it is fixed to the wall. Therefore, you will not get a chance to have a very thorough hair washing as you cannot draw it nearer your head.
Shower body jets are designed for them who are not satisfied with a fixed showerhead which has a steady downward water flow.
Shower handsets act both as fixed showerheads and shower body jets. You can choose to fix it by placing it into a bath cradle in a hanging position and you can also remove it there and be directed to spray water to specific body parts.
And lastly, the Dual Showerheads consist of two showerheads connected by a finished metal bar. It is fixed to the wall covering more surface area and delivers twice the amount of water spray.
IMO, the most savings in showers comes from a button that has to be held down for the water to flow. Plus some type of radiant heating so that people feel warm even when the water is off.
People Online People Online: Visitors Visitors: 151 Members Members: 0 Total Total: 151
