Ductless Mini Split Wall Units
Last Post 15 Feb 2011 02:22 PM by peter_ac. 26 Replies.
rykertestUser is Offline
14 Aug 2009 01:33 PM
FYI, I typed in ductless mini split into the youtube search bar and there were some good videos to view showing the in's and out's of the ductless.
cfl-greenUser is Offline
24 Sep 2009 12:58 PM
Our new house is going to have a seperate detached "game room" building, approx 600sf. Would it be a good idea to go with a mini-spit in this small building rather than a conventional system?
24 Sep 2009 03:57 PM
Posted By schmausser on 09/24/2009 12:58 PM
This would be a great option. Getting a small heat pump would be ideal with a wall unit and would be the least expensive. if you look online for ductless depot or go ductless.com you can see what a small system with 1 unit would cost. ANy of the major brands would be fine. Fujitsu, mitsubishi or daikin.
24 Sep 2009 04:11 PM
schmausser;
I have used a Ramsond heat pump(9000btu) ...1 unit handling 528 sq. ft. on 2 levels, th e units come precharged and prewired and are idiot proof to install
ntvinh986User is Offline
16 Nov 2009 02:28 AM
Posted By TechGromit on 05/17/2008 11:53 PM
Can anyone explain to me why ductless mini split air conditioners units are any more efficent that window air conditioners? I understand that the system is composed of an outdoor unit, an indoor mounted evaporator unit, but i fail to see how this can be any more efficent than a window air conditioner with both of those parts intergrated into the same unit.
[/quote]
Hi all, I am a new member of forum. Would a newcomer be warmly welcome here? Good day you guys!!!
__________________
http://animewatching.com
16 Nov 2009 04:41 AM
ntvin986;  welcome!
3 reasons:
1.   Mini splits only require a small dia. hole in wall for refrigerant and electrical connections. making sealing easier than a unit in a window frame.
2.   They can be mounted on any wall for maximum effectiveness
3.   Heat pumps have greater SEER ratings available
peter_acUser is Offline
Having a window AC unit is also a security issue. It is much easier to break-in.
http://www.minisplitsguide.com/
People Online People Online: Visitors Visitors: 148 Members Members: 0 Total Total: 148
