New Dishwasher Recommendations
Last Post 12 Jun 2010 07:32 AM by cmkavala. 13 Replies.
SummersUser is Offline
12 Mar 2009 07:08 AM
Hey All,
Interested in experiences or opinions concerning replacing a dishwasher with a new, more efficient model on the market today. Energy Star ratings are a given, but I am particularly interested in how quite they operate.
Thanx Glenn
The Cost Effective Answer to Concrete Corrosion
CHuntMDUser is Offline
23 Mar 2009 06:49 AM
Replaced a 17 year old DW last Summer.  What a world of difference in noise level.   Most places that sell DWs will include a db (decibel)  number the lower the better.  It's not a normal number scale but logarithmically (sp?).
If item A is rated at a 70 and item B is 80 the item B is 10 times louder that item A.
So just 1-2 decibels can make a difference.
CH
TomWSUser is Offline
23 Mar 2009 11:40 AM
Bosch.  No question.  I installed one in our previous house after a remodel and we were stunned to find how quiet and how little soap it uses.
When we moved into our current house we immediately replaced the working contractor's model with a Bosch.  The contractor's model (GE of course) was practically new, but required us to run it late at night with our bedroom door closed (and we still heard it, water hammer and all).  With the Bosch, we can be in the Family room, which is on the other side of the island from the dishwasher, and we don't know it's running.
I'd be hard pressed to ever use another dishwasher again. Warranty service is good - they came out immediately to 'repair' ours when it seemed that it wasn't cleaning properly and the 'issue' was merely that we were using too much detergent.   There was no charge for the call.
Tom
06 Apr 2009 05:01 PM
Another testimonial to the quietness of operation of a Bosch dishwasher- it was impressively quiet compared to the GE that it replaced.
DaveSUser is Offline
03 Sep 2009 07:31 PM
Posted By Summers on 03/12/2009 7:08 AM
Hey All,
Thanx Glenn
Check out Fisher & Paykel. That's where we ended up. They have to 2 drawer washer that is very effecient. We don't actually have it yet since we are in the design stage of building a Green home. But after our research, it's on the list.
Good Luck,
DaveS
03 Sep 2009 09:03 PM
Watch out for the two drawer models.  $$$ and not the most reliable.  I replaced a 17 year builder's grade GE with a SS Kenmore last summer.  Amazing difference in sound (or lack of  ;)  Very happy.  I also looked a Bosch and LG.  Most will have the db rating just remember that db is a linear scale and each point is a decent difference.
ARdolsonUser is Offline
03 Sep 2009 11:55 PM
Be careful, some (most) of the drawer dishwashers can't handle a large (normal) plate.
oldmilwaukeeUser is Offline
16 Oct 2009 03:38 PM
We like our Bosch model SHX55M05UC. Super quiet. Dishes get nice and clean without pre-rinsing them. The energy ratings on these newer dishwashers don't disclose the insane amounts of electricity they use when the heating element comes on inside of them (e.g. on the sanitize settings). No worse than the electric element in a hot water tank, but if you've moved beyond an electric heat elements for energy reasons (we have, we live off grid), then it's just something to be aware of.
building an off grid timberframe home...<br>massiehouse.blogspot.com
16 Oct 2009 03:48 PM
Posted By ARdolson on 09/03/2009 11:55 PM
I checked the Fisher & Paykel and found there is plenty of room. And if you lay the racks down it can handle most large pots. Normal large plates are not problem. We are going with two seperate drawers verses a two drawer system.
Lowe's didn't have the two drawer dishwasher to look at and that may have a problem room as you mentioned.
NicoleCUser is Offline
16 Oct 2009 05:37 PM
Posted By CHuntMD on 03/23/2009 6:49 AM
Not necessarily.  The human brain does not perceive all frequencies the same, so one thing at 70 dB can be "louder" than another at 70 dB, and a given measurement of dB could be weighted for this or not.  The minimum difference in noise level a human can perceive is 3 dB.  You can't hear the difference between 50 dB and 51 dB.  Additionally, appliance noise tests are not performed the same way across all manufacturers.  A noise test which takes place in a room that is highly sound absorbing will generate completely different results than a test in a more reflective room or a dishwasher, say, resting on a tile floor in a small room with glass windows, granite counters and a marble backsplash.   Guess which one manufacturers prefer to test in?
So while the lower the number the better in general, take them with a grain of salt and as a general guide, not as any real hard and fast measurement.
geomeUser is Offline
18 Oct 2009 05:36 PM
We love our energy star Kenmore Elite (2 years old) made by Whirlpool. Since dishwashers and other items in your house have many electronic components, I thought I'd mention this - if you get power surges where you are at, invest in a whole house surge suppressor. We lost the control panel in our dishwasher after 23 months, the control panel on our gas range, and a hard wired smoke detector. No problems after installing the suppressor.
rkillough-millerUser is Offline
06 Jun 2010 11:58 AM
Old Milwaukee;  I built and am living in a timber frame home in central Mass.  I'm looking to go off the grid in a few years as PV and wind turbine tech. improve.  A few questions, if I can.  (1) How's the electic useage for your Bosch diswasher? (2) Can you run the unit WITHOUT engaging the heating element? (3) Do you use a gas or electic on demand water heater?  If so, what do you use and are you happy with it?   Any light you can shed on this issue would be appreciated.  Thanks, Russell
jerkylipsUser is Offline
11 Jun 2010 11:31 PM
for those looking for appliances, take a look at ajmadison.com . We just ordered all of our appliances for our new house from them (scheduled to be delivered in about a week). They were the best price we found by far, offered free shipping & in home delivery, and because (for us) it's out of state, no sales tax. We were going to order our appliances through sears, before going this route. At sears we would get an additional 10% off by using a sears card. Even with that, aj madison beat them by about $1500 overall!!
Posted By rkillough-miller on 06 Jun 2010 11:58 AM
We have a Bosch DW model# SHE5AL02UC   that is run off our tankless propane and can be run with or without heating element
cost $479.00
People Online People Online: Visitors Visitors: 278 Members Members: 0 Total Total: 278
